How do you extract only video and not sound using virtualdub?
I am loading a .avi (of divx type) in virtualdub.
I know to get sound only, save it as .wav but when I save it as .avi, it has both
I'm not sure 100%, but I know there is some Demux option in VirtualDub, which you can save just the AVI with the Video only
try looking through the Save AVI options.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
load your avi or ? then under the audio tab select
No Audio. then under file select save as avi. -
remember to set the video to 'direct stream copy' so you don't recompress the video but just extract it
N0SoopForU already gave the answer : "Audio" -> "No Audio".
Then save the avi. Wheter you recompress it or not (full recompress or direct-stream), there will be no audio in it.
How To Extract One Video From Three
By Treeant34 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Apr 2012, 11:48 -
How do you extract only the video with AVIdemux?
By Djard in forum Video ConversionReplies: 2Last Post: 30th Jan 2012, 17:25 -
Extract video
By iami in forum Newbie / General discussionsReplies: 11Last Post: 23rd Aug 2009, 15:20 -
extract frame from video
By ahidayat in forum Newbie / General discussionsReplies: 7Last Post: 28th Feb 2009, 02:45 -
Extract video from DVD
By prl in forum DVD RippingReplies: 8Last Post: 8th Jan 2009, 15:35
