Ok so this might be a dumb question but I just ask it ANYWAY just to be sure..
I was wondering.. IF I have an avisynth script that would have some filters that require yv12 colospace... Do I need the converttoyv12() LINE in the script AT ALL If I'm doing -XVID- to DVD??
BECAUSE isn't YV12 already xvid's DEFAULT color output??![]()
Yes, you would only need the conversion if your source was not YV12.
The script will tell you if it's needed by throwing an error when you start the encoding.
AviSynth "ConvertToYV12()" command - correct placement in script?
By spicediver10191 in forum Video ConversionReplies: 2Last Post: 11th Dec 2010, 19:15 -
Audio help needed please
By BrainH in forum ComputerReplies: 1Last Post: 27th Jul 2010, 17:46 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
What is ConvertToYV12?
By ultraman36 in forum Video ConversionReplies: 1Last Post: 13th Jan 2008, 07:23 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
