Hi all,i cant get WinDVD creator 2 to recognise my USB capture device(ADS DVD Express) Anyone know how to force it to recognise it as an input option?
There is reference in the help file to USB capture from a cam,and it says to open the device's program first,then open WinDVD.Even that dosent work,and it will only show my video card in the list(which will only capture in NTSC,and i want to capture PAL,hence the USB method)
If this program wont support USB,do you know of a video capture prgram that will ?
Any help you can offer would be appreciated
thanks
I capture using WinTV USB2 and WinDVD Creator 2 so I guess it does capture from some type of devices. Not sure if that helps but it answers your question
Doesn't that come with Ulead DVD MovieFactory? Why would you use WinDVD Creator?
WinDVD Creator v2.0 thru v2.5 works just fine with my HP USB TV/PVR device (Bali). -
Thanks for the replies.I've actually sorted it now,sold the ADS device and got a Plextor DivX / MPEG Capture device instead,and it works great with the bundled software !!
cheers
cult
Re: getting interactive chapter marks windvd creator 2
By tomcat862 in forum Newbie / General discussionsReplies: 1Last Post: 28th Feb 2008, 14:38 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39 -
Cannot get audio in Windvd creator 3 under windows vista.
By syllinx in forum Capturing and VCRReplies: 0Last Post: 13th Jul 2007, 23:43 -
WinDVD Creator 3 not recognizing .AVI
By wmrjw in forum Authoring (DVD)Replies: 4Last Post: 28th Jun 2007, 18:15
