I was going to post in the Newbie/Gen'l forum but decided to do it here..
I don't even know where to start.. I've read a couple of authoring guides, like DVDAuthorGUI and DVD Maestro (Maestro is way too confusing for me) and managed to author a DVD of a TV show from my ReplayTV hd--but NO menus. Now I'm trying to make a simple/beginner's menu for the show. I can't even get past the part on how to grab in image from the show as a background pic for the menu...?? Do I simply just hit the F11-Save(??) key or the PrtScn?? Eventually, I'm going to want to do motion menus (but baby steps first, I guess).
For simple testing purposes, I tried importing a random jpg image into Photoshop and converted the image size from original size to 720x480 (from the Image/Image Size dropdown menu) to be DVD-compliant, then imported into DVDAuthorGUI (Menu/Create m2v still dropdown).. But I get an error.. From the error log, I got this: **ERROR: [jpeg2yuv] Unsupported sampling factors! Is this b/c I don't have an actual project imported into the app?
If I can't even get past this initial step, this is going to be one trying learning curve for me.. Can someone please recommend/link me to a complete/detailed guide that includes how to convert various images to DVD-compliant images for menu purposes? Are there any freeware apps that create motion menus?
Results 1 to 10 of 10
https://www.videohelp.com/~liquid217/readme.html#troubleshooting
An exerpt:
-Jpegs exported from Photoshop do not convert to m2v stills correctly (or they are all green).
This is caused by a sampling issue. Reviewing the log, you will probably see
To resolve this, simply lower the quality of the jpeg exported from photoshop, then make the m2v still. -
Try DVDLab (30 day fully functional demo).Cheers, Jim
My DVDLab Guides -
You could look at WAX2 from http://www.debug.com mode for making the graphics/clips, and DVDauthorgui to put it all together. Perhaps not as straight-forward as pay-to-play software, but it will do the job.
IMO, TMPGEnc DVD Author is the package with the best "what it can do" vs "learning curve" factor. You can create pretty impressive stuff (to those who don't see it's made with TDA!) without knowing much at all.
/Mats -
Thanks for the replies..very helpful. I'll stick with DVDAuthorGUI for now and learn the basics, then move on to something a bit more flexible and involved.
Just to confirm, let's say I've got an hour's worth of video that I've converted to DVD-compliant mpeg-2 files.. and want to make a still pic menu w/subpics for chapters at every 10mins. I want 1 large still pic for the menu background (it'll fill up the entire screen, or most of it) and 6 separate smaller still pics (sub-pics for each chapter) overlayed onto background pic with simple text beneath each chapter subpic indicating which chapter #.
Is there a guide out there showing how to prepare the above material for importing into DVDAGUI (or any other authoring app)? This is basic stuff, I think, but I'm unsure how to do it.. For example, I need to select 7 images total (1 for the main menu still and 6 subpics). Do I just power up PowerDVD and play my mpeg-2 files and 'capture' the 7 images from various points in the video? If so, um.. how do I capture and save? I think you just hit a certain key (either PrntScrn or F??) but sorry, i just don't know. I know once I've got 'em, I'll have to resize to 720x480 NTSC for DVD-compliance. But how do i resize the subpics? -
You're going about it the hard way.
You say you want to learn the basics...you should learn basics on a good authoring app, that also allows growth and flexibility.
I really suggest you try DVDLab, as it makes what YOU want to do (background pic, chapter pics, chapter points, menus etc.) quite simple.
Guides below in my sig.
If you need further help on creating motion menus, or you have trouble with the chaptering bits, don't be afraid to ask.
FYI Tmpgenc DVD Author will also do what you want quite easily, although with not as much flexibility (imho).Cheers, Jim
My DVDLab Guides -
/Mats -
Originally Posted by jbenj01
Good Luck!
RogThere are many ways to measure success. You just have to find your own yardstick. -
Thanks for the replies all. I'll try out the DVDLab demo (interface kind of resembles Maestro.. yikes!
Burnman, I'll also try the Gimp or paint.net as you suggest and give it a go with DVDAG to see what happens.
I'm beginning to realize how important is to understand overall DVD structure conceptually (i.e., to visualize how it's all inter-related). i've seen reboot post pics of how menus are linked to various parts of the DVD.. it's confusing as heck.. well, back to the learning curve.. Thanks again to all.. and I'm sure you'll be hearing from me... soon..
help required on making simple but 'deep' dvd menus
By lancealittle in forum Newbie / General discussionsReplies: 9Last Post: 18th Sep 2010, 06:34 -
A program for JUST making custom DVD video menus?
By gom in forum EditingReplies: 6Last Post: 23rd Oct 2009, 04:05 -
Episodic DVD + menus Authoring
By Instant Martian in forum Authoring (DVD)Replies: 48Last Post: 22nd Apr 2009, 11:42 -
2 questions about DVD authoring
By ihmcjacky in forum Authoring (DVD)Replies: 23Last Post: 5th Jul 2008, 04:21 -
Making DVD video taking very long time. For advice.
By seymoria in forum Authoring (DVD)Replies: 4Last Post: 11th Mar 2008, 02:59
