Here's my goal: Take 10 jpg's, apply 4 seconds to each image, then compile(the string of images, if you will) into an avi or mpeg. Is there a software package out there that will take stills, set some time to each still then crunch it all into a video?
I'm interested in a stand alone mpeg/avi file.
I'm not interested in a stand alone "photo album cd-r" that can be played on a stand alone DVD.
TIA!
Guest34343Guest
If you want a really small file and it doesn't have to be edited together with other video, here's a neat trick. Use VideoMach to load the stills. Set a frame rate of 0.25 fps!
Each still will play for 4 seconds.
Donald Graft -
If you have (or can get/buy) Adobe Premiere, you can make slide shows easliy. I made a slide show using Premiere that was 26 minutes long, with music and transition effects and it looked great!
How to convert jpg pics to avi?
By pmolson in forum Video ConversionReplies: 24Last Post: 22nd Oct 2014, 16:50 -
mp3 + jpg -> avi/mp4/mkv?
By disgust in forum Video ConversionReplies: 10Last Post: 22nd May 2012, 10:25 -
embedding jpg into avi, xvid files
By pheonix rising in forum EditingReplies: 0Last Post: 14th May 2011, 13:54 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 09:06 -
Trying To Use JPG Stills In Premiere Pro 2.0
By HarveyCee in forum EditingReplies: 14Last Post: 11th Jun 2007, 12:23
