hey guyz,
does anyone know of any other programs to encode avi to rmvb besides using real producer plus 10 and easy real media producer??
the program is frequently hanging when i am encoding the file.
thx for your help
Results 1 to 12 of 12
https://www.videohelp.com/tools?tool=RealAnime
plus procoder and cleaner"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the site for that tool is down.. i can't get into the site.
do you know of any alternative sites? -
seems to be gone
anywayz... i found that program at other site. the thing now is. when i encode the program it crashes, saying that there is some error when it is reading the anime file. is there some sort of setting problem becuase all these anime's are donwloaded from animesuki.
are there any recommended codecs or codec packs that i should include? -
i guess the question would be - why bother ?
real media is not real popular really (around here) - for good reason .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i am using the latest k lite pack now...
if you know of any better programs, pls let me know
thx -
if it is already divx or xvid -- you are not going to save much room - or none at all .. but ARE going to kill the quality .
i know i will kill the quality. but its not much.
does anyone has any other programs that they can recommend?
Power Producer Problem
By travbickle in forum Authoring (Blu-ray)Replies: 0Last Post: 24th Aug 2011, 13:30 -
Power Producer 3
By RED SHIFT1 in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2010, 01:15 -
Proshow Producer 3.2
By nace in forum Authoring (VCD/SVCD)Replies: 2Last Post: 13th Aug 2008, 02:29 -
Anyone know Power Producer (first version?) very well?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2008, 12:37 -
Doubt on the Easy Real Producer
By bebado22 in forum Video ConversionReplies: 7Last Post: 10th Dec 2007, 12:44
