2.0 RC 1 - Released 17 Jan 2005
- Fixed setting PAL->NTSC as a default option in the settings.
- Fixed random crashing when loading assets.
- Fixed various “focus” bugs.
- Fixed AVI to MPG ignoring audio settings.
- Fixed closing application during operation not stopping all processes.
- Added Pan & Scan (Pioneer Fix) for MPEG 2 (SVCD) assets.
- Improved Pan & Scan (Pioneer Fix) over v1.5. Quicker and bugs resolved.
- Added minimise to tray. Save memory this way!
- Added various GUI improvements.
- Added RIFF header support. Mpegs with RIFF headers are converted when added to the asset window.
- Several other bug fixes.
Results 1 to 14 of 14
Whooo whooo!
Great job indeed mate! Keep it up.
When do you estimate we will have the option to determine a pre-size of the out-put DVD?
Make it real to choose a DVD size of 4.7GB or other, rather than running DVDShrink after...
Another VERY VERY important issue especially for foreign loyal users that use your tool is the ability to add and configure external subtitle!!! Please please make both happen ASAP.
May the force b with you mate
JB -
Thankyou
Will look at it very soon.
need to uninstall old .
one useing it right now
thanks for the updates -
I got a problem with converting more than one file in svcd2dvd rc1
I run the program
it converts the part 1 and part 2
makes a dvd folder
but when i burn and play back in a standalone dvd player the 1ist half plays fine but the 2nd half jumps skips
seems like the join screws the dvd player up
? anyone got a fix for that please -
Does it happen in your software player or other standalones? Did it happen with other releases?Originally Posted by britincanadaSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I just checked on the COMPUTER and played back in DVD ROM drive all ok
so looks like its a dvd player problem i have 2 apexs
tryed + - discs in dvd player burnt at 12 /8/4 and 2 speed still the same problem its all ok if i put 1 movie file on a disc but when i try to do more ie a movie split into 2 parts thats when the problem happens seems to be a join problem that only my dvd player picks up
im useing ritex discs i tryed verbatium too
thats for the reply
great program -
Have found what i assume to be a bug or an oversight.
I converted a vcd told it to burn using dvddecryptor and it all went fine.
Then i created another one and forgot to delete the dvd output folder and instead of it renaming the new output or saying should it overwrite it just added the new one onto the old one so i ended up with a dvd with 2 films on instead of 1.
I assume it should have realised the name was the same and either rename the new file or delete the old one?
Not a major problem but if you are doing a few and forget to delete the old outputs you waste a lot of blanks -
ok. I shall add a warning that this is about to occur, recommending that the user changes the output folder or something.... Thanks for the headsup.
Thanks for the update. I'll give it a try this weekend. Just to make sure - do you consider this program good for camcorder DV source to DVD (NTSC, interlaced)? Which encoder(s) does it use?
Thanks again -
Give it a go. I have done several, indeed i was going to write a guide on camcorder to DVD using SVCD2DVD....
The encoder is based the avcodec library which is the same as that used in QuEnc, for example. See MPEG-2 Encoders 2005 TEST! CCExTMPGENCxPROCODERxMCxQUENC for comparisons....
I have to say that in the next release there will be 2 pass encoding and a "fit to DVD" feature which may benefit such usage.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
I only have one question, Chris. If I purchase this release, will I still be able to update as improvements and updates are made without having to pay for the software again? I apologize if this question has already been answered. I have searched but haven't found any results. Thanks in advance.
p.s. Awesome piece of software dude. The best I have used. -
Once you become a registered user you are entitled to all future version & updates of SVCD2DVD.
AV Linux 2.0 Released!
By GMaq in forum LinuxReplies: 7Last Post: 21st May 2009, 08:51 -
Divx 7 released
By Peakr in forum Latest Video NewsReplies: 44Last Post: 2nd May 2009, 09:52 -
VobBlanker 2.1.3 released
By jsoto in forum Latest Video NewsReplies: 12Last Post: 26th Jul 2007, 19:22 -
OGGCConv 1.01 Released
By lindoran in forum Latest Video NewsReplies: 0Last Post: 11th Jul 2007, 00:23 -
Safari for PC released
By dcsos in forum Latest Video NewsReplies: 6Last Post: 12th Jun 2007, 12:40
