Is there a program that will do a convert MPEG1 files to Divx in Batch mode? I have hundreds of MPEG1 files that I would like to convert to Divx.
Results 1 to 10 of 10
VirtualDub
/Mats -
procoder 2 can do batch mode encoding to divx .. two different ways to do batch mode ..
Could you explain the reason why you want to convert to divx because maybe I'm wrong but as much as I know, the majority of DVD standalone players do not play movies in the divx format. So wouldn't it be better to convert the mpegs to a DVD standalone standard?
Hello and thanks for the replies. I'll look into Virtualdub. I've tried Dr Divx, but couldn't find a way to do batch.
John,
I'm converting to divx because my televisions are hooked into my computer (via my Gateway connected DVD player), so I can stream MPEG1,2 and Divx to the tv's, it works great. But I've already got 3 hard drives that are almost full. So converting to divx would be great as it will give me more room. -
In case you want to try batch encoding in Dr.DivX (or do multi-pass batch encoding) ..
After you have set the encoding attributes (you can save the settings as a profile if you want to apply the same setting to many files), go back to the 'Encode Video' screen and you'll see a 'Defer job for batch encoding' checkbox at the bottom of the screen. Click on this and press 'Encode' and the current job will be added to the 'Job List'.
On the left-hand menu of the the 'Job List' screen is a 'Single Encode' option, click this to set up another job in the job-list.
When all your jobs are set up, go to the 'Job List' screen if you are not already in it (by clicking on the 'Batch Encode' option on the left-hand menu when you first start-up Dr.DivX) and just click on 'Start' and batch-encoding will begin. -
bunyip,
Thanks!
I'm going to try that...I've just started using Virutaldub with VXID codec (and frankly don't care for the results much). I think I'll reinstall DrDivx, and try as you suggested.
Convert Divx to Xvid batch
By nick7461 in forum Video ConversionReplies: 8Last Post: 2nd Oct 2021, 11:37 -
shrink avi/divx in batch mode
By volam1 in forum EditingReplies: 1Last Post: 5th Jan 2010, 20:20 -
Batch re-mux .mkv to DiVX w subs
By nbarzgar in forum EditingReplies: 6Last Post: 3rd Jun 2009, 06:18 -
Batch Convert Avchd To Divx Or Ipod
By leo_bassani in forum Video ConversionReplies: 2Last Post: 30th Aug 2008, 16:07 -
DivX conversions to DVD
By catricric in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2008, 07:21
