  1. Banned
    Dec 2004
    SE4
    When VHS videos wear out they go flickery, can AVI's do that on the PC or can you watch one as many times as you like and there will be no quality loss??
    Also what's the only thing to affact playback of movies on the pc the only 2 i can think of is bad fragments and a codec issue..is there anything else??
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    No - DIGITAL files can never "WEAR OUT". All that can happen is quality loss from converting from one format to another. Or if they were improperly encoded in the first place
    Kevin
  3. Banned
    Dec 2004
    SE4
    Thanks very much mate, also thanks for the quick reply..
  4. Banned
    Dec 2004
    SE4
    even when u encode on virtual dub doing a direct stream copy on video do u use quality then??
  5. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    The FIRST time you capture/encode a video to a digital file that is the BEST you will get it. So if you do the capture/encode properly it will look the best it will ever look in the digital form.
    Use a video bitrate calculator found in the tools section under LISTS on the left of the screen. Use the proper bitrate first to ensure it will fit the target medium
    Kevin
