I have tried everything and nothing seems to work.
Please help.
A picture is worth a thousand words, but a good camera is worth about a thousand bucks.
Could you elaborate on "everything"?
I just converted an avi with MSmpeg4 video and pcm audio last night with ffmpegX. I had to use the DVD(mpeg2enc) preset instead of the DVD(ffmpeg) preset, and I also had to switch from decoding with QT to decoding with mplayer. The audio came out with a mangled name, but renaming it back to mpa seemed to work fine (it plays in QT player at least). -
Originally Posted by stanislawski
maybe not enough for wav / aiff
- pcm to aiff
- soundhack
be sure to set the right header
and if all fails mencoder does the job -
That's an odd question. You don't want AIFF for a video DVD and you don't want AC-3 except for a video DVD. So what is the reason you're trying to convert the PCM audio?
There are lots of audio applications that will resample PCM 48 khz audio to AIFF's 44.1 khz. It takes an AC-3 encoding application to convert to AC-3. -
Hey Frobozz, I want to convert it to aiff then from aiff to ac3 because DVDSP3 won't accept pcm. And because ac3 's are much smaller files, leaving more room for video.
A picture is worth a thousand words, but a good camera is worth about a thousand bucks. -
MPEG Streamclip can demux to m2v and aiff, among other demux options.
http://www.alfanet.it/squared5/mpegstreamclip.html
Shrinking entire dvd with pcm to ac3
By emodio80 in forum Newbie / General discussionsReplies: 29Last Post: 26th Jul 2011, 05:17 -
For Developers ; Video Sample having TWO AC3 and PCM, with en-SUB
By Bonie81 in forum Latest Video NewsReplies: 1Last Post: 13th Oct 2010, 01:30 -
Convert PCM to AC3???
By ivano09 in forum Video ConversionReplies: 6Last Post: 17th Feb 2010, 13:08 -
PCM vs AC3
By Reading Bug in forum AudioReplies: 14Last Post: 1st May 2009, 05:34 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45
