I have a laptop that has a much lower audio output than it used to. Its a compaq Evo running XP, and now when i crank all settings to maximum i can still listen in headphones without it being too loud.
The problem started after somone else used the computer, presumably after he pressed the hardware volume settings on the laptop case.
I have checked the visble volume sliders available in XP, activated all settings i would wanna try, disactivated all line in and such. Yet the sound is very weak.
This goes for mp3 playback as well as video files.
The computer does have ac3 codecs installed, i reckon.
I have tried booting the computer into (knoppix) linux, and then the sound levels were high as normal, which leads me to believe that this is not a hardware problem, but perhaps some very well hidden setting in Windows, or some file that has been changed.
Any ideas ?
cheers
Results 1 to 11 of 11
Have you checked Sounds and Audio Devices in control panel in the audio tab under playback and checked to see if the master volume control and wav controls are not set too low?
Originally Posted by johns0
yup, they are maxed .... -
i have the same problem with my compaq laptop. i had a thread going a few months ago i think. theres not much you can do about it. its not anything with the computer, its just the sound card doesnt have very much power. its a way for compaq to save money and to get a tad more battery life out of the computer.
hi sitlet,
do you seriously mean that its because the computer doesnt have enough juice ?
Shouldnt really be the case here, as we are running the machine on the power outlet when whe have the problem
could you link to the discussion you mentioned?
thanks -
Did you make sure the speaker (external volume) volume was turned up? Usually there are volume controls on the laptop that control this. Also, make sure your sound scheme under your sound properties uses the correct speaker setup. If you are using a surround or some other type of setup other than the laptop schem, your volume may be significantly decreased
On the mixer, check to see if there's an option for Advanced Controls under the Options tab. Mine does and there's a checkbox for 'Loudness'.
Nothing can stop me now, 'cause I don't care anymore. -
Doubt this will make much of a difference, but you could try going to 'Start->Control Panel->Sounds and Audio Device Properties'. Then in the "Volume" tab, there should be a section labeled, "Speaker Settings" and you'll see an "Advanced" button. If you click on that, it'll take you to a dropdown menu where you can choose what kind of speakers you have (ie - "headphones", "stereo speakers", etc).
Originally Posted by smearbrick1
Iäm thinking maybe one could re-install some soundroutines from CD or something.
Thanks for your ideas, people! -
late reply:
culdnt find any solution to this, it was probably buried deep within the software/OS , so i re-installed the soundcard, that did it!
something was corrupt .....
software options to zoom/crop on a low-end laptop?
By lee09 in forum EditingReplies: 2Last Post: 8th Sep 2011, 02:36 -
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 07:02 -
HDTV Audio output is too low. Help
By daustemd1551 in forum AudioReplies: 1Last Post: 1st Nov 2009, 20:08 -
Low Audio Output
By house141 in forum MacReplies: 6Last Post: 17th Jan 2008, 23:16 -
best video output for laptop??? HELP!
By italianjeremy in forum ComputerReplies: 3Last Post: 17th Dec 2007, 10:11
