I've been attempting to capture some old Hi8 tapes through my Canopus ADVC-100 and they are filled with dropouts. These tape dropouts range from a few pixels to full lines.
High end hardware TBCs have multi-line dropout compensation. Is there a non-realtime software process that does the same thing or better?
I know some Matrox DV cards can do this.
There is some AVISYNTH stuff FulciLives posted in the RESTORATION forum sometime last month.
You've moved beyond just capturing. You're wanting to restore the video. Moved to RESTORATION forum, more help there.Want my help? Ask here! (not via PM!)
edDV, you did not mention if you are already processing the video signal with a full frame TBC. If you are not, you may want to give that a try. Even a TBC without DOC might stabilize the frames enough to prevent dropouts during capture. My Feral A4:2:2 has DOC, but I have not used that feature on a capture so I can't comment on how well it works.
I don't know if there is an effective way to correct dropouts after capturing... but LS is right, FulciLives would probably know if there is.
Hi8: achieving perfect captures
By dogbait in forum Capturing and VCRReplies: 2Last Post: 11th Feb 2010, 01:09 -
Dropout on VHS-C
By epitome in forum Newbie / General discussionsReplies: 6Last Post: 16th Sep 2009, 19:18 -
Sony Hi8 has been defective but want to play the Hi8 tape
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06 -
Hi8 vcr, better playback than a Hi8 camcorder?
By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11 -
How to Deinterlace using Motion Compensation?
By Undead Sega in forum Video ConversionReplies: 18Last Post: 15th Oct 2007, 09:58
