  1. I'm trying to Compile a DVD in DVD-LAB and keep getting an error message when I hit the start button. Error reads " ! out of memory" out of memory where?...... have lots of room on HD. The est. DVD size is 1.68 GB I can't find any info in the help sections.
    PLEASE HELP!!
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Sounds like a software issue. Have you tried checking their website for updates?
    Google is your Friend
  3. What have you set up as the temp, and compile folders?
    Are you using NTFS or FAT32?
    Cheers, Jim
    My DVDLab Guides
  4. I've had the same error messge. But I've also had strange crashes with DVD Lab which is kinda of annoying esp after ponying up the $.
    I've been assuming it's a ram memory related issue since a reboot solves the problem.
    Is your's a recurring problem or can you continue using DVD Lab after reboot ?
  5. In the working window, close all the menus and stuff you're finished with. This frees up all the memory needed for them.
    Cheers, Jim
    My DVDLab Guides
