Hi
is anyone know where can i found program about "dvd size",
after i select my audio and language and other things that i want.
a simple program that calculate all things and show me the total size before i burn(to know if the disk is accept size).
TNX
https://www.videohelp.com/tools?tool=VideoHelp_Bitrate_calculator
And moving to DVD Authoring ... -
i cant believe u been here since 2002 and are asking bout a bitrate calc
He registered quite a while ago, but this is actually his first post on these forums. Anyway...
You want a simple one so the ones already mentioned will suit you best. Eventually you may want to look into something like FitCD. It takes ALOT more variables into consideration and allows you to get a more accurate prediction of exactly what bitrate you need to use. -
bloody hell, registered like 2 years, 2 months ago and posts now
thats incredible -
sorry, since 2002 i dont have internet connection and sorry about this forum. next time i will check the forum where to write things
TNX & SORRY
How do I calculate bitrate for 320x240 .m4v?
By dave692 in forum DVD RippingReplies: 1Last Post: 5th Aug 2011, 17:31 -
A Question On How To Calculate Frame Size When Resizing Vid for DVD
By hydrophonicaudio in forum Newbie / General discussionsReplies: 13Last Post: 21st Feb 2011, 08:53 -
calculate quality of a movie??
By Cazz in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2009, 08:55 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 10:32 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 11:51
