Hi there, can anyone help?
I have 18 different recordings on my E85's HDD and would like to know if there is anyway I could change the order of the recordings. Some of the things I have recorded are part of tv series' and would like to put them all together in order instead of them being all over the place.
Is it possible?
Thanks in advance
I have the previous version, the E80. The only way I know of is to dub the programs you want to keep to DVD-RAM, delete them from the HDD, then dub the DVD-RAM back to the HDD. But, why not just edit out the commericals, and burn them to DVD-Rs in the order you want them? That way you can keep them forever, watch them anywhere, and not have them cluttering up your HDD. DVD-Rs are so cheap theres almost no reason not to!
Thanks for the reply, I usually back the programmes up onto dvd-r but until then just wanted some order on the hdd. Thanks anyway I'll try the dvd-ram tip
Changing the order of the audio streams in a rip
By JDMils in forum Blu-ray RippingReplies: 4Last Post: 17th May 2011, 18:03 -
Changing the order of chapters in idvd
By caspera in forum MacReplies: 3Last Post: 16th Sep 2009, 01:34 -
Changing the Order of audio on a DVD
By PBoy in forum EditingReplies: 5Last Post: 15th Aug 2008, 00:02 -
Changing Filed Order in IFO-file
By Dima P. in forum Authoring (DVD)Replies: 3Last Post: 22nd Jan 2008, 13:37 -
Corrupt HDD Camcorder recordings ? Need content, ideas appreciated
By PushPull in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Dec 2007, 02:07
