I downloaded the divx 5 codec and player from the link in tools.
The video will not play with Media Player but will play in the divx player but only a few second of the clip will play.
How can I get a video requiering the divx 5 codec to play with media player?
Thanks for any help
By 'media player' do you mean that garbage that comes with Windows (with pretty skins?).....DivX player is even worse....shiteware
Why not use a 'real' media player?
Try
BSplayer
Core Media Player
Media Player Classic
Zoomplayer
all the above will require you also installing FFDShow (and possibly AC3Filter)
OR
VLC..aka..Videolan (self contained). -
I may be second guessing you here, but if you still can't get it to play more than a few seconds with any of those players, VLC especially (Which will play about anything), you may have some bad frames. A lot of DL'd DIVX vids off the web are that way.
I usually put them into VirtualdubMod and it will tell you if you have bad frames or a timestamp problem. Then if I just want to view it, I do a direct stream copy. Makes a quick copy and leaves the bad frames, but the file will play though. Or you can edit out the frames and save, but that takes a little longer.
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 18:58 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 02:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 18:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
