First off i would like to thank you for making this excellent program.
The way is use SVCD2DVD is to get the megs converted first for use later on different dvds. This works fine but in Version 2 everytime it uses the mpegs it add another _DVD on the filename. So after I have use the file on a few dvds it looks like this :-
filename_cd1_DVD_DVD_DVD.mpg
It didn't do this in version 1.
Cheers
Andy
Yes i have the same problem. I think there is something wrong with the dvdfolders.exe
It also creates 4x800mb in only 2 minutes, VIDEO_TS.IFO is only 12kb of size and no creation really works on my dvd-player. -
Originally Posted by nawo69SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Where may I get the last version of the x264 - 64 bits version codec?
By daniel827 in forum EditingReplies: 5Last Post: 27th Dec 2011, 18:55 -
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 03:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 18:20 -
Is the 'academic version' different from the commercial version of Vegas 8?
By jbigfoot in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2008, 00:19 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00
