Sometimes i download movies and they wont pay because i am missing a certain codec to plat them.
What is a codec and how do i use them?
Mark V
Results 1 to 17 of 17
Mark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
Maybe your question should be what is search?
http://www.google.com/search?hl=en&lr=&c2coff=1&safe=off&oi=defmore&q=define:codec -
Ok i understand what one is now.
What type of codecs does Mac use or am i kinda screwed if the file i want to open was done on a IBM?
Mark VMark V
Most codecs exist on both Mac and IBM platforms. A few very old and very new codecs might be only one platform. Quite rare though.
So if i download a movie and it says " can not open due to missing codec " i should just trash it then?
Mark VMark V
No, you should investigate what codec it is asking for
first, then if it doesn't exist, then trash the movie.
Easiest way to do this, try playing the movie in VLC,
and using the Info command, find out what codecs
it is using to play back the movie. *shrugs*"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I searched first.....
VLC looks like an IBM program, is there a site that has it for a Mac?
Mark VMark V
Thank you.
Mark VMark V
That's because Toast relies on QuickTime, not VLC. So use VLC to identify the codec. Then get that codec for QuickTime, if available.
How do you use VLC to identify the codec?
I went through all of the prefrences but still cant figure it out.
Mark VMark V
ok one codec says XVID and the other says mpga.
Am i correct?
If i am how do i find out if these are in my quicktime or how do i add them to my quicktime?
Is there a big file i can download with these in the program or something?
Mark VMark V
That's XVID video and MPEG-1 audio.Originally Posted by Mark V
The 3ivx decoder will handle XVID just fine. The installer will add the codec for you.If i am how do i find out if these are in my quicktime or how do i add them to my quicktime? -
Ok one works now but no sound from it.
Mark VMark V
I am trying DivX Doctor II, so far it worked on one movie.
I will post my results when its done with another movie.
Mark VMark V
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 20:26
