I have had some compatability problems on discs that I burn on the JVC DR M10 unit when the discs are over 2 1/2 hours long
I always make copies of these discs on my pc first using nero before I give them out using 8x TY and riytek media copied at 6x.
I have had complaimts about discs skipping and fast forwarding or not playing after a certain point.
Is there any reason that discs recorded that are over 2 1/2 hours should not be the same as discs that are less the 2 hours long as far as compatibility goes?
Thanks for any suggestions.
Sounds more like a burner problem. I never had any problems with JVC discs playing.
It could also be that you are using Nero.
I had a DVD player that choked on all of my Nero burns (even with apps that used the Nero burning engine). Now I only use ImgTools and DVDDecrypter.
No problems since. -
The horizontal frame size changes from 720 to 576 (VR Mode) or 352 (Video mode) when recording time is over 2-1/2 hours. If you use video mode, this should not create compatibility problem. I have transferred many hours of recording recorded in 3-hours mode to the PC without any problem. If you use VR mode, your authoring software should re-encode for you.Originally Posted by standish
Do not use VR mode.
I would bet money that the problem is bad RITEK discs that you are re-copying onto. Not AT ALL related to the JVC. Could also be FAKE TY media.Want my help? Ask here! (not via PM!)
JVC DR-M10 Loading and Repair Question
By usaf64 in forum DVD & Blu-ray RecordersReplies: 555Last Post: 1st Jul 2013, 11:33 -
HOT DEAL: St. Louis Craigslist - $75 JVC DR-M10 DVD Recorder
By jbd5010 in forum Off topicReplies: 2Last Post: 16th Mar 2011, 08:21 -
problem recording with jvc dr-m10
By restauroman in forum RestorationReplies: 3Last Post: 28th Feb 2010, 11:47 -
JVC DR-M10 help
By colt4523 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2008, 06:53 -
How do JVC combo VHS/DVD recorders compare to M10 or M100?
By DGinnetty in forum DVD & Blu-ray RecordersReplies: 7Last Post: 27th Sep 2007, 12:14
