Hi i was wondering if there's a way to correct the audio of a video file that has a lot of background noise.
Also how can you increse the volume on a vcd?I've tried the filters from tmpgenc but it returns me an error!At last what's the normalize option for audio?Thanx!
You can try using a dedicated audio editor, such as soundforge or goldwave. Play around with the equaliser and other filters to see what happens.
As for the VCD, demux the audio and increase the volume in the audio editor, then add it back to the video and burn. Should fix the problem.
Normalizing should try to balance very load and very soft parts of the audio by reducing the dynamic range of the audio track.Read my blog here.
I i'm not keen in using audio editing software,so would you plz describe more thorough how to adjust the filters?
Also what's a good value to increase the volume to?
Thanx! -
If you have Nero, it comes with a wave editor. You will have to demux (seperate) the audio and video. Load the wav file in Nero (or Audacity) and select the noise removal filter. These really only work for things like static or consistant background noise. Not something like street noise or someone talking in the background. You also need a small section of the audio where you can only here the noise so that the filter can anaylse it.
Audacity will read mp2. I am not sure about Nero. You could open the file in Vdubmod and save the wav. To find the background noise, you will will have to find a section of the file when there is nothing else going on. Usually at the end or beginning. It might only take a second or two of sound.
Volume correction in XMediaRecode still not fixed
By Djard in forum AudioReplies: 0Last Post: 27th Apr 2012, 19:14 -
MP4 video correction in audio
By onlygk in forum Newbie / General discussionsReplies: 2Last Post: 23rd Nov 2010, 02:08 -
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57 -
Audio sync correction help
By andy99 in forum AudioReplies: 0Last Post: 16th Sep 2008, 15:38 -
Audio skew correction causing static in begining of audio.
By NextJinGamer in forum AudioReplies: 1Last Post: 3rd Sep 2008, 15:33
