    Sep 2004
    Denmark
    I vould like to make an vcd vith slideshow yhere start automatic when put in my DVD player, how is this posible, the easy way
    thanks.
    svaage
    Nov 2003
    Moreno Valley, Ca
    Not sure if this is vcd as you state as I just burn as data cd
    I use a free download program called photoplay I got at ZdNet. com
    When used to create the autorun and the files are in the burn directory the disc autoplays slideshow in pc.
    For standalone dvd players that are jpg capable, I think all you need to do is burnthe jpg files as a data cd and the player will automatically play as slideshow. Atleast that has been my experience
  3. Auto start of VCD in your Standalone player is down to the player nothing you can do about it but most do just play the disk without having to do anything in my experience. There are various tools for making slideshows (ULEAD) as well as others do them just select VCD as the type you want to create.
    You may want to be a bit more specific if this does not answer your question.
