Hi all![]()
im trying to watch the MacWorld 2005 Expo but i keep getting 400: Bad Request in quicktime pro 6.5.
what does this mean and how can resolve this, thanks for any help.
kas
Moved to the Newbie/General Forum.
Uninstall quicktime, and install quicktime alternative.Originally Posted by kas187
What is your QT Client's network topology? (ie. are you behind a firewall,
are you using DHCP that is behind a NAT, are you using an HTTP Proxy
for your Web surfing?)
One suggestion is to open your System Preferences, go to QuickTime,
click on the "Connection" tab, and then "Transport Setup" button.
What transport is listed as your Transport Protocol? UDP or HTTP
If UDP, then try switching to HTTP (using RTSP Port ID 80)
Also, you might try clicking on "Auto Configure" button.
Final Cut Pro, gives me GENERAL ERROR when exporting to Quicktime
By Huntr777 in forum MacReplies: 8Last Post: 30th Sep 2011, 14:26 -
Error 2048 Quicktime Problem (Home Movies)
By cliffm10 in forum Software PlayingReplies: 0Last Post: 19th Apr 2010, 11:06 -
Quicktime parse error converting mpeg-1 muxed to DV or mpeg 4
By jglass in forum Newbie / General discussionsReplies: 0Last Post: 15th Jun 2008, 20:51 -
AVI conversion error in Quicktime Pro
By oldsalt in forum Newbie / General discussionsReplies: 1Last Post: 24th Nov 2007, 17:16 -
Error on Uncompressed 10-bit 4:2:2 1920x1080 QUICKTIME to -> MPG
By peejeedee in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 19:04
