Results 1 to 12 of 12
  1. Has anyone had any experience with any program that accepts
    a segment of vob (not with ifo and bup that goes with it)
    as a clip (video file)?
    It should have the sound on when the menu i s added and then
    burnt as a DVD.
    Some of the programs accept the vob but the sound is not there
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Use DVD decrypter to rip whatever clip you want out of the DVD. You can convert it diretly to mpeg.
  3. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    why not create some IFO's for it?
    won't DVDLAB or something accept VOB's and take the audio info from the VOB. How about Tmpgenc DVD Author, will that also take the stream info from the VOB?
  4. Originally Posted by thecoalman
    yes using dvd decrypter I have taken out a vob
    I then used chopper Xp to cut out the segment
    I have cut out a few of them as short vobs
    I want to use them to create a menu and use those vobs to make a new
    DVD and burn it.
    How do I convert those Vobs into Mpeg ( you say it can be done with
    decrypter ...Is that correct?)
    If that is possible then that is great , then it can be fed into
    many authoring programs that accept mpeg2 and not vob
    (somehow they are not able to strip the sound to transcode. However they
    are able to do so with Mpeg2 files)
    thanks for the tip
    (that is decrypter will convert vob into mpeg2?)
  5. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You can rip segments out with dvd decrypter and output as mpg.
    See the guides section https://www.videohelp.com/guides
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    To answer the actual question in the title Tmpgenc Dvd Author will accept vob files as an input source there are others too just look in the authoring section under tools on the left of the screen <------
    Kevin
  7. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you can use DVDShrink to grab the VOB's also
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Of course I meant using TDA AFTER ripping the vobs
    Thanks for the clarifacation macemx (didn't mean to confuse the poor guy ).
    Kevin
  9. Originally Posted by MackemX
    Incidentally, I found out that you can use the old "show biz" to accept
    the Vob files too.
    The old show biz just about accepts anything you throw at
    It produces DVD file (mpeg2 that conforms to the standard) in a reasonable time that is acceptable to most of the authoring programs.
    Thanks guys for sharing your tips
  10. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    Is the TDA trial a fully working version?
    Damn it!....I just saw the date of the last post....3months old.....errrr....
    What We Do In Life, Echoes In Eternity....
  11. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    http://www.pegasys-inc.com/en/download/tda16.html
    Limitation: This version is freely usable for 30 days. After this period, a valid Serial Number key is necessary to unlock the software and use it.
    Yes.
    If in doubt, Google it.
  12. Member daamon's Avatar
    Melbourne, Oz
    And you can set the start and end points in TDA too, so no need to use another tool before bringing into TDA. i.e.:
    Rip VOB with desired scene in using DVDDedrypter or similar.
    Load VOB into TDA.
    Select start and end point to define actual desired clip.
    Repeat with multiple VOBs (can be same one used a number of times) as required.
    Author and burn as normal.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
