Results 1 to 12 of 12
  1. Hi every one a little help i have three 738 mg cue,bin video files i want to burm them on a dvd not 3 cd's nero or any other program i have will just let me do one it is one whole movie i don't want to use 3 cd's if i don't have to thanks again
    #3 lives on
  2. Extract the Mpegs with VCD gear and join them with Tmpeg. Then Burn.
  3. Thanks dec but they are not mpegs they are bin/cue files will that work with them
    #3 lives on
  4. Banned
    Sep 2004
    Inner Circle of Thought
    You did not listen.
    Extract the mpegs from the bin files.
  5. Member monzie's Avatar
    Nov 2003
    The Village
    Cue files contain NO information regarding the DATA at all, they are purely CD burning parameters for the .bin (the bin contains the data).....open the bins and look for the AVSEQ~ files (these are mpegs) and extract with ISOBUSTER.
  6. as mentioned,
    1. ISOBUSTER to extract the mpeg whatever is in the bin files
    2. TMPGENC (personally, I would use www.thefilmachine.com) to chain them together into 1 file
    3. Authoring software TMGPENC DVD Author or something like that
    4. burn
  7. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Originally Posted by macleod
    as mentioned,
    4. burn
    as above, but I use VCDGear to do the extraction - there's no difference either way though.
    If in doubt, Google it.
  8. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    as mentioned,
    4. burn
    I wouldn't join them, too much chance of causing sync problems. Just take each mpeg and let the authoring process join them.
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    True - reading disorder on my part
    Let TDA or whatever you're using to author do the joining for best results (IMO)
  10. Hello, I followed the advice listed above to extract the avseq files from both .bin's. Now I have two avseq DAT FILES. I can't seem to go any futher with it. I've tried a few authoring programs but can't seem to find how to move forward. Can anyone lend any advice on what it is I need to do now with the two DAT FILES to make the video onto dvd?
  11. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
  12. Member kush's Avatar
    Jul 2004
    Near "Pacific Park", USA
    Are they VCDs? If so, then the video would be fine for putting onto DVD (VCD res of MPG1 352x240/288 is in DVD spec), all you would need to do is change the audio sample rate from 44.1k>48k (as per DVD spec)..Should be some pointers on the process somewhere in the previous link. ps - check out Gspot to find out what format the .DAT's actually are.
