Sense the Philips dvp642 and kiss dvd players can't play every format, all subtitles, etc why don't people build their own dvd players instead so it will play all formats ? Not a actual dvd player but like another pc, not all top of the line stuff, that way you can upgrade the codecs when need be, etc. Its like you can release your own updates whenever see fit instead of having to wait and hope new upgrades come soon.
Results 1 to 13 of 13
The xbox will do all formats and is even cheaper and not to much more than the Philips and less than the Kiss depending on which one you bought! I like the Philips but it doesn't make sense if the xbox isn't to much more and supports everything.
Cost for one thing got the 642 for 60$,How would a cheap Computer look in the TV room,My wife would Kill me, Plus if I have somthing that wont play I just stream it to the TV, But i just find it all a Pain in the a**.
does the xbox support all of the formats without modification? if not, what is needed for it?Originally Posted by max2
The xbox needs to be modded with some sort of modchip or a software mod. It needs Xbox Media Center installed to play the video formats. Once you have that done, you have one of the best progressive scan 5.1 DVD / multi format players out there.
The posts are basically correct, but I must disagree with max2 on the cost issue. Anyone who is interested can look into it like I did and I'm sure they will come to the same conclusion. Doing everything required to mod a Xbox is more expensive than you might think. I thought seriously about the Xbox mod and realized the Philips DVP-642 was so much cheaper I couldn't justify buying and modding the Xbox. Cost is all relative and what was too much for me might not be for someone else. I do agree with what max2 hinted at but didn't come out and say - Kiss DVD players are too expensive.
Hello,Originally Posted by max2
www.xbox-scene.com for more info on modchips and softmodding
Actually I think I read something on there about a progressive scan hack for the xbox output feautures if thats important to you
I have an Xbox and I must admit it doesn't have the best picture for a DVD player. Actually both my cheap Zenith DVB410 and my new Phillips 642 have a way better picture. The great thing with the Xbox is that it will pretty much play anything you through at it. I use it as a last resort (it's not THAT bad).
Philips DVP642 vs DVP3560 Which Player plays More File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Dec 2010, 15:39 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 22:54 -
Question about AVI files and DVD player Philips DVP 5982
By jtrinc in forum Software PlayingReplies: 1Last Post: 24th Nov 2008, 20:23 -
How do you make screen size bigger on Philips dvd model DVP642?
By jkristoff in forum DVD RippingReplies: 9Last Post: 23rd Jul 2008, 05:33 -
Philips DVP3960 DVD player behaviour question
By m_burlock in forum DVD & Blu-ray PlayersReplies: 2Last Post: 18th Jun 2008, 15:07
