Hi, can someone comment on the following. I've backed up 2 different movies using 2 different methods and the one click method seems to be a perfect 121 backup while you can see a slight difference in quality to the original using the other method.
I used dvdxcopyexpress on one film and decrypter and shrink on the other. Would one click software compress it different to shrink or would they be completely the same. The movie I used copyexpress on seemed to be perfect while decrypter and shrink wasn't that good. The length of both films were roughly the same (just over 2 hours).
Results 1 to 13 of 13
what answer are you looking for
so many variables
use the method that your happy with -
If you are doing a comparison test, you can not compare different movies. One movie may look bad to begin with. Always compare the same movie to do comparison tests. There is no way to say one is better than the other unless it is done to the same movie.
Imagination is More Important Than Knowledge -
The answer i'm really looking for is, is 1clickbackup software any better apart from being quicker and less complicated. I'm very happy with decrypter and shrink but would prefer to pay if something is a lot better.
Cheers. -
Originally Posted by gav223
No....dvdshrink and dvddecrypter are not complicated.
Then why are you asking?Originally Posted by gav223
Why pay for something when there are free programs that do the same thing if not a better job?Originally Posted by gav223 -
The reason i'm asking is, as the old saying goes you only get what you pay for. I Thought that maybe because your paying for software it would produce better backups in some way or another. I'm not that educated when it comes to computers so i'm trying to gain some knowledge.
Cheers. -
Ive owned a few paid for programs and dvd shrink and decryptor do the same job as the others. Theres not a huge, world of diff. between what they all do anyway, but I was using dvdxcopy and now I just use dvd shrink and decryptor, one reason, aside from it doing the same burn job, is that they dont put that silly copyright warning at the start of the movie like dvdxcopy does. Man it stays there for a lifetime!!
gav223
Different copy programs use different transcoding engines so yes, there may be a difference in quality among transcoders. As suggested earlier you shouldn't compare two different movies and two different transcoders. Use one movie to compare dvdxcopyexpress and dvd shrink.
Check the tools section for comparisons of different transcoders and how users rate them.
Good luck.It doesn't matter who you vote for. The government always gets in. -
@gav223, you don't get what you pay for in the world of software
DVDShrink will be good enough for most people but for some it's just not the one even though it's free. It's nice to have a choice as some programs produce different results depending on the DVD and the settings you use. The morale of the post is take into account people's opinions but use what's best for you and nobody else 8)
@mattyboy, someone in the forum wrote a guide (if not a program) to get rid of the daft 321 warning
I know I got rid of it on my own but not until after I burned 100 movies or so!!!
LOL
, oh well now you know
should have come here as a solution been around since they put it in
is that solution here on this forum? or in the search? My brother and I took out a file that removed the mesage but I forget what one it was. And i might use dvdxcopy again when I get some other media to do testing (when Im bored). Do you remember what the software was called, I tried a few differnet names/titles in the search bar but I couldnt find anything.
321Gone I think, here is the guide
https://www.videohelp.com/forum/userguides/127933.php
https://www.videohelp.com/forum/viewtopic.php?t=127933
you can use any of the blanking tools now also to get rid of the crap
Decrypter to Shrink to Imgburn?
By visionman in forum DVD RippingReplies: 3Last Post: 19th Jan 2011, 12:06 -
D v d Decrypter and shrink
By Leftbehind in forum Authoring (DVD)Replies: 3Last Post: 7th Oct 2009, 02:18 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
I can't rip with DVD Shrink or DVD Decrypter
By Baldrick in forum DVD RippingReplies: 77Last Post: 10th Feb 2008, 12:46 -
RipIt4Me, DVD Shrink, and DVD Decrypter on Vista?
By RowMan in forum DVD RippingReplies: 1Last Post: 24th Oct 2007, 22:45
