  1. well guys,
    i d/led the rm converter from boilsoft's site.
    well in that u can convert with 2 decoders namely boilsoft's decoder and real media plugin.the conversion with boilsoft's decoder,the audio isn't in sync. with video.so could ua tell me a way 2 fix it or could u give me a link 2 d/l the real media plugin
    thanking u in advance
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Try extracting and converting the audio and video seperately, then remux them back together.
    Google is your Friend
  3. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    I purchased Boilsoft's crappy product as well, my condolences to you.
    this program does not work!
    I had the exact problem that you are having, their "support" section told me, in very bad Engrish, to "use VirtualDub, that's what it's for".
    Use TINRA.
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
