Quick and simple question, I have a program in the backround of my computer downloading a file, if I am encoding while downloading will it effect encoding at all ? When the file pops up saying I'm done will that mess anything up while the encoding is going on ? Just want to make sure I'm not gonna risk the file that I'm encoding
downloading + encoding
shouldn't hurt anything*, it might slow the processing a bit adding seconds to the encode.
*so long as this is a file you are downloading, not a stream.
downloading while video capturing or importing DV over Firewire
I would wait for the capture or DV transfer to finish since they are not fully buffered and may drop frames. -
Aww what now, I think I kind of know what your talking about. But the file I'm downloading has nothing to do with what I am encoding. Its a power point presentation. I think you might of been saying if I was encoding the video that I was currently downloading.Originally Posted by edDV
I think the DV tip was a freebie, as you didn't mention DV capture in your post. Unless you are doing realtime encoding (eg. on the fly encoding of DV to Mpeg-2) the only cost will be encoding speed. You can browse, download, play online games and it wont effect the outcome of the encode. Encoding is pretty CPU intensive, and doesn't like to share, so you may find everything else is slow.
Read my blog here.
If the download is a file - no problem.
If you are streaming data or capturing video, the encoder running flat out may choke the former.
The OS will make sure the file gets through, it can't do much to protect a stream.
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
Avi files not running properly
By Skyline in forum Newbie / General discussionsReplies: 6Last Post: 25th Dec 2008, 10:22 -
DVD encoding issuses w/ progressive fames plays back as interlaced. SOLVED!
By ty1er in forum DVD RippingReplies: 1Last Post: 19th Aug 2008, 09:34 -
Encoding - Audio fine but video running fast
By adeleander in forum ffmpegX general discussionReplies: 3Last Post: 23rd Dec 2007, 15:11 -
problems running avi files on ext player( clips shifting postions)
By auto7890 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Aug 2007, 04:11
