I've just bought a DVD burner (Pioneer DL). I made my first DVD fine (using Nero). I'm trying to create another, significantly longer) DVD (about 1 hour) from my Sony HandyCam. My problem is with the capture - it starts fine but by the end it is stuttering, has gaps and the audio goes out of sync. I tried using uLead Moviemaker to do the capture - it was better but still the same problems. Can anyone please help?
Results 1 to 9 of 9
Are you using DV video? If your computer specs are up to date and you have a 20G HD, I'd say you were running out of space. DV is about 13G per hour. If DV, you could also use WinDV.
Stuttering and audio sync problems may also be something running in the background on your computer. You could try shorter captures, but then you would have to combine the video files. -
Originally Posted by redwudz
I'd suggest you get an additional drive dedicated for video capture. At least a 40 gig model. -
Firstly, how good is this forum! A reply from across the world (I'm in Perth. Western Australia) in record time that I reckon is on the mark.
Secondly, please explain for a beginner, what you mean when you say "Are you using DV video?". What is DV video? I simply plug the HandyCam in via he Firewaire and select DVD when asked what sort of disc I want to burn.
Thirdly (and I think this is related) what does thecoalman mean when he says " You might be able to get away with it if you captured directly to mpg". How do I do this?
Again, great help in record time. This is a great forum. Thanks muchly! -
I also don't know what people are talking the first time I read thru this forum.
Check here https://www.videohelp.com/glossary
Then you can interact with them smooth, fast and clear.
Im a N00B too. -
Whichever method you choose I still suggest getting another drive. -
Thanks again. Using either uLead or Nero the capture output is mpeg (mpeg2 I assume), NOT AVi. Soooo, I should try capturing to AVi, author my DVD and then burn it.
BTW capturing about 1 hour of DV direct to mpg is about 3.5 Gb. Does this sound correct? From what you say capturing to AVI will result in the same file size?
BTW2 - yes more storage on the way. I should just buy a new computer! -
You can probably find a lot of posts here on DV >> DVD with a forum search.
The method I use is to transfer the DV to the computer with WinDV (I like to monitor the transfer), then edit in VirtualdubMod (Filters and editing), with the Panasonic DV Codec installed.
Then I frameserve to TMPGEnc encoder. (Look at frameserving in the Guides section.) After encoding, I use TMPGEnc DVD Author to author and usually burn. Frameserving keeps from using up extra drive space with an intermediate edited file.
There are plenty of variations on this, different programs and different methods.
Definitely go for more HD space. As far as encoding speed, with my older computers I just set up the encoding when I went to bed and didn't really care how long it took. The computer would shut off when it's done. -
DV AVI is also a compressed format but not quite as much as mpeg, it has a higher bitrate. It will not be the same file size. For 1 hour its about 13-14 gigs about triple the size of your file.
As I said there is nothing wrong with capturing to mpeg but for the best quality particularly if your going to edit capture to AVI, edit them to create your mpeg.
Loss of Audio Sync after cutting (Avidemux)
By Maverick-X in forum EditingReplies: 4Last Post: 14th Oct 2011, 15:12 -
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
Loss of audio sync during streaming
By TheOnlyMFH in forum Video Streaming DownloadingReplies: 0Last Post: 3rd Nov 2008, 12:58
