Can anyone tell me how I can get my pc to accept cookies for certain sites. I never had this problem until my cable internet service got disconnected and I started using AOL 9.0. I assumming, AOL is blocking cookies. Is there something that I can do?
Results 1 to 13 of 13
do you still use IE with AOL 9.0 (I have no clue how AOL works). But in tools/internet options, there is a setting for cookies and you can change the settings around. There is also the general settings for low/medium/high risk for websites you can modify.
AOL uses IE as the core for there web browser. You should just be able to go to start>control panel>internet options>privacy and set the cookie options.
Also when you visit a site down in the lower right hand corner you'll see a small red icon that looks like a do not enter sign if AOL is blocking a cookie. Double click it and it will bring up the options for cookies. -
Hello,
This should really be in the computer forum though.... :P :P :P
I like the part about leting somesites through the higher security setting.
Mike -
If you really want to get drastic hit the advanced button and select overide automatic cookie handling. Then select block first part and block third party cookies, check the box next too all ow session cookies.Originally Posted by mike1061
If you run into a site that won't work correctly because of cookies and you want to allow it double click the red circle in the lower right that looks like a do not enter sign. It pops up each time a cookie is blocked from a website. You can allow cookies on a site by site basis as needed. -
thecoalman
Thanks, I will look into this (try it).
I already set the privicay slider all the way up, and manuly set up my favorite sites to alow cookies. I am still trying this setting, but it looks like I'm having troubles with the secondary pages at some sites. Having to log in to view them. For example I had to log in to type this, but I was able to view the message. We will see after I look at everything I look at each night.
Thanks Mike
Deleting cookies?
By neworldman in forum ComputerReplies: 3Last Post: 21st Jun 2011, 12:52 -
Cookies
By Jomapil in forum ComputerReplies: 4Last Post: 5th Jan 2011, 04:30 -
IE8 website cookies removed after each reboot
By Nintendo Fan in forum ComputerReplies: 13Last Post: 2nd Mar 2010, 21:48 -
Are cookies considered malware?
By alegator in forum ComputerReplies: 6Last Post: 8th Jul 2009, 16:24 -
Does VHelp make any use 2o7.net cookies?
By gll99 in forum ComputerReplies: 11Last Post: 28th Apr 2009, 05:09
3 answers in 5 minutes
