First time using this piece of software. I was using the NEROrecode section. I loaded up my .avi movie and cut out the credits with the edit feature. I then made a menu and chapters. The program seemed to start burning fine. Roughly an hour and a half into the burn, the DVD is almost finished. I then receive and error saying "Unable to create the disc structure. Burn process failed!" Then it asks if I want to save the error log entry. WTF? The DVD appears to be burned, but it will not play in any DVD players including the one that burned it. Help!
Doesn't sound like it started burning but just went through the encoding process.
Anyhow the first thing you do is eliminate the esiest things. Make sure the software your using has the latest updates and get the latest firmware for your drive. -
Originally Posted by thecoalman
Originally Posted by firebirdude
Sectors Error While Burning
By rckowal in forum Authoring (DVD)Replies: 4Last Post: 16th Dec 2010, 08:19 -
BDMovie Maker burning error
By Michael33 in forum Authoring (Blu-ray)Replies: 0Last Post: 21st Jul 2010, 12:50 -
DVD burning error! =(
By ll ReNeGaDe ll in forum Video ConversionReplies: 44Last Post: 21st Oct 2007, 18:33 -
Error when trying to burn to NeroVision or ConvertXtoDvd.
By Swanee in forum Authoring (DVD)Replies: 9Last Post: 12th Aug 2007, 21:04 -
Error at around 20% while burning
By the_rider in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2007, 20:11
