i checked this in the avi codec, and this is what i got:
File : 306 MB (306 MB), duration: 0:24:24, type: AVI, 1 audio stream(s), quality: 85 %
Video : 277 MB, 1590 Kbps, 119.880 fps, 640*480 (4:3), WMV3 = Windows Media Video 9, Supported
Audio : 29 MB, 167 Kbps, 48000 Hz, 2 channels, 0x55 = MPEG Layer-3, Supported
i use vlc media player to watch my files, but this file plays sound but shows no pictures
it plays on my windows media player tho, why?!
what codec do i need?
my knowledge of vlc media player is limited but, i had a problem with media player classic (with exception that my problem was audio not video) like this. You might want to try different video output settings in vlc media player. If its playing in windows media player it seems like you would have the necessary codecs. If that fails you might want to try a different program to check what codec the file needs. Gspot is pretty darn usefull.
some will play and some wont.
By kushy66 in forum Newbie / General discussionsReplies: 9Last Post: 22nd Aug 2011, 21:32 -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
xp wont play movie
By natty in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2010, 12:26 -
8x DL wont play in PS3
By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 14:16 -
JVC Wont Play New DVD's!
By Raxxor in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2008, 13:02
