I have not been able to find any documentation (both in Nero, on their site, or here) as to what "DVD High Compatibility Mode" actually *is*.
Can someone here tell me?
- Tim
I believe it simply adds null data to your project if it is below a certain size. Apparantly some DVD players have problems reading DVDs with only a small amount of content on it, or so Nero says. I've never heard of this actually happening.
Thanks, Adam! I hate features that go completely undocumented.
But then, Nero *is* a kinda weird product.
- Tim -
I made some 15min. DVDs for a client that didn't work for him, even though they worked fine for me After researching the matter, I discovered that DVDs are supposed to contain at least 1GB of info (even if some it is useless stuff in an extra folder). So I remade the DVDs with 1GB+ and they worked just fine. Apparently its part of the DVD specs, but most players seem to do okay anyway...
I read somewhere it's for DVD+R/RW only.Then in Nero 5.5 the box said "for certain players such as XBox",in Nero 6 there's no mention of Xbox.
In my experience it does nothing but write a longer lead-out,the file size is the same with or without it enabled. -
Yes. There is a dokumentation inside the Nero SDK:
dvd_high_compatibility: Used for better compatibility of burned DVDs as
at least 1GB will be written. -
http://www.pioneer.co.jp/dvdrrw_e/techinfo/techinfo_1.html
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 15:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 03:17 -
DVD on Sony Walkman X, "SP" template but high bit rate
By dch888 in forum DVD RippingReplies: 1Last Post: 6th Dec 2009, 15:19 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 19:02
