Correction, DVD.
Results 31 to 60 of 61
Hello stiltman,
Just started to print on TY-R hub printable - matte.
Inner is 23mm
Outer is 118.5mm
I use Epson print CD s/w
If I select 118, I will have a very small white ring on the edge.
If I select 119, It will have way too much ink of the side.
I do not know how to print them properly.
I do not like to use 119 and end up with extra ink that I need to wipe off.
I am afraid that some ink will stay and somewhat, may damage optical drives. -
Had the same problem with ?????brain fart???? oh yeah, the inner hole for some Prodisc S04's. They seemed to be slightly off. I just printed them as usual. I didn't wait for it to dry. Then I noticed I could smudge the inner ring a little. I really doubt .25mm of ink will cause any problems at all. The media will suck most of the moisture out of it via wicking. Least it hasn't caused any problems for me.Originally Posted by RickTheRed
Are you sure the hub is 23mm?
I'll add it to the list -
Stilt,
Inner is really 23mm, not 22 or 21.
Edit: outer is ok at 119mm -
added
BTW, thanks for the input -
I'm a little confused -- wouldn't you get a bigger white ring if you select 119? I have a different problem -- I'm using Canon's software, printing TY matte -- but I cannot select a size beyond 118. So I'm getting a white ring as well. And no matter how I size the image, I can't get rid of the white ring.Originally Posted by RickTheRed
Spiffy -
No one has upped the sizes and stuff, so no, not yetOriginally Posted by johnjohnvh
Epson R200 on
Prodisc hub-printables
Ritek hub rpintables
118mm - 23mm
no problems at all
edge to edge printing
I'm working on a template for CorelDraw to print with Epson. It is a pain because everything has to be done manually and requires many tests. But that is my fav so I have to do it. Anybody has one yet? -
I would start a new thread asking the questionOriginally Posted by spiffy
Thanks stiltman, will do.Originally Posted by stiltman
Back to the subject of Print Area: Does anyone know if there is there a brand of discs not listed that has a larger hub diameter than TY (44 mm)?
Spiffy -
Curious why you would want less print area. Usually, people want more print areaOriginally Posted by spiffy
I have some older DVDs I'm backing up that have much smaller labels (large hubs) than the current discs today. I am trying to preserve the label scans as close to the original as possible without trying to fill in the extra printable areas with colors and what not.Curious why you would want less print area. Usually, people want more print area
Spiffy -
Curious, what's the media code on those?Originally Posted by Gen-An
How would you use these templates to print to a Canon IP5200 CD Tray? I guess they need to be carefully positioned in a larger template?
Do you know what's the measurements for the Maxell CD-R? The Maxells I bought came in a package, no spindle. Kind of an awkward way to sell blank media if you ask me.Originally Posted by Gen-An
I hope it's OK for me to ask this question in this thread... But is the Ritek White matte (118mm x 42mm) still available anywhere?
I looked at the product image from Supermediastore.com, and the disc looks suspiciously like the same size as the TDK PrintOn and the Verbatim, which has a smaller hub area.
Looks like Rima.com only carrys the Hub Printables, and Supermediastore no longer sells sampler packs... So if anyone has any info, I'd really appreciate it.
Thanks in advance!
Spiffy -
Great original idea this, although at least one template needs an alignment job…
This is the Verbatim 119mmx21mm template with an overlay of the same measurements done in Illustrator, which is much more precise than Photoshop when doing this sort of stuff (and easier too for that matter). I have this one and the Taiyo-Yuden full-face and I can either export the AI files into Photoshop and make a raster image or convert them to PDF, which works very well too.
Of course maybe it's no big deal and just my OCD.Satan's Ex-Son-In-Law -
I added
Verbatim DataLifePlus DVD+R DL white matte
119mm x 35.5mm
After running a copy through last night, 35mm is just a little too small by about .5mm
The template is for 119mm x 36mm -
Hello! I am just wondering if anyone has some measurements for the BenQ White Matte Printable(Non-Hub Printable)? Thanks
Uploaded new template for TY hub printables. I changed it to 119mm x 22mm. It should actually be 118.5 (sometimes) as I've noticed a little extra ink around the outside edge. Funny, but it doesn't happen all the time. So I just got used to running a soft cloth around the outside each time.
Oh well, use at your own risk
question
downloaded the "Verbatim white matte hub printable" template
flawless printing, except the bottom of the inner circle is slightly off leaving a white line, have wasted a couple of disks fiddling with the measurements
using Acoustica CD/DVD Label Printer and a Canon IP4600, if that matters
ones I used
EDIT: fixed it, had to tinker with the inner hub but now have a perfect template
Sorry if this sounds like a stupid question; but is it just a matter of getting a mm ruler and actually measure the (diameter) printable areas of the discs? I need to get the dimensions of some of the newer blanks, especially the BD-Rs; but I've never actually done any measuring before...
Yep, just measure it.
Hi,
stiltman you've done a great job putting these templates together, I am using Aone DVD-R 4.7gb - Full Face Printable discs and I have found they are 117mm x 23mm.
I have downloaded one of you're templates, but I am not very good with photoshop and I don't understand how to change it to this size.
Can you give me any advice or help.
Guts -
Just set your round selection tool in Photoshop to 18mm and click
then drag it as close to the right area as you can
You can also setup 4 guides, one on each side the you'll know you've got it pretty much right on.
18mm for printable area in the center seems too small, but then I haven't purchased hub printables except TY's in a long time
Printable DVD Slipcover Templates
By nwo in forum MediaReplies: 0Last Post: 24th May 2010, 18:04 -
Quick Media Converter lifehacker.com most popular free windows app 2008 ?
By balou in forum Latest Video NewsReplies: 77Last Post: 17th Mar 2009, 03:09 -
looking for silver hub printable DVD media
By PharmBoy in forum MediaReplies: 6Last Post: 30th May 2008, 06:31 -
relative quality and best burn speeds for some popular media
By JohnnyBob in forum MediaReplies: 32Last Post: 8th Feb 2008, 18:44 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 11:29
