Results 1 to 12 of 12
  1. Is it possible to use an XP PRO install disk to "repair" windows XP HOME?
    I've got a computer here that I'm fixing and my XP Home disk is scratched
    This guys computer has so much spyware on it that it won't read the onboard ethernet card or the PCI slot card. I got most of the spyware off but there's a few that refuse to be deleted. I tried everything I can think of. Spybot, hijack this, AD-Aware and some other from cnet.com. Nothing will take them off. Even the "Add-remove programs" window is screwed up. The "Uninstall" buttons are gone
    Aside from formatting and reinstalling XP do you guys think a "repair" will work?
    Or should I slick it and start over?
  2. Banned
    Sep 2004
    Inner Circle of Thought
    No
    You need to format and start over. In which case, you would then be running xp pro.
  3. With that amount of spyware, a repair won't do you any good. You will be better of reformatting the computer.
  4. Member Soopafresh's Avatar
    Jan 2004
    Turn Off "System Restore" and try Webroot's SpySweeper. They have a 30 day on their site.
    Also, try the cleaning in Safe Mode.
    Chances are, however, that you'll have to reinstall.
  5. also use Microsofts new spyware remover. Its actually pretty decent. Gets things others miss.
  6. Originally Posted by Poppa_Meth
    That program rocks!!
    It's in my arsenal now
    Nov 2003
    Moreno Valley, Ca
    No
    do a web search for barts pe builder.
    it can create a bootable xp cd from existing xp installation
    from this clean xp boot envioment if you know where to find the bad files they can be deleted.
    I have not tried to do a xp install/repair from this but is a useful cd to have
  8. Banned
    Sep 2004
    I know all about Bart's pe, but you still cannot use a xp home disc to repair a xp pro install nor can an xp pro disc fix an xp home install.
    You need to have the disc that you used to do the original install.
    That is like saying you can use your windows me disc to repair windows 2000.
    It is not possible.
  9. but you could repair xp home or pro with a different disc of the same os, i assume, provided you had the serial # for that disc. correct? i don't see why not.
  10. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    You don't need the 'original' CD but the version of the OS has to match, i.e. Home to repair Home or Pro to repair Pro.
    Nothing can stop me now, 'cause I don't care anymore.
  11. Banned
    Sep 2004
    That's what I meant, but it came out wrong.
  12. Well I only ask because XP pro has all the drivers/networking additions that Home doesn't. So i thought that since the core files are the same that it would work.
    I reformatted the dumb thing anyhow
