Tried to do a search beforehand but .....
I have a 4.8GB mpg file exported from EyeTV software for buring DVD in Toast 6. The file is 0.4 B too large to fit on a 4.4GB DVD disc. What can I do to downsize the file? Many thanks in advance.
Already having an mpeg you might try to trim or edit the file with Streamclip since you'd not have much to remove to make it fit.
Or, you could simply drop the mepg on Toast and "save as disc image." Once that done. mount the image and run the disc through DVD2One or Popcorn to shrink it down to the appropirate size. FFMPEGX has a tool to do this too, and would be the cheapest option, but I've not tried it myself.
Hope this helps.
Regards -
Another tip is to edit EyeTV recordings before exporting them.
Also see Reduce EyeTV Recording Size to Fit DVD (forum link) for more discussion of that topic, which alph has nicely summarized here. -
Thanks for the replies, guys.
Alph, I did exactly what you have said. Made a disc image with Toast and drag it into Popcorn. It worked seamlessly. Somehow, the image quality of the DVD burned with Popcorn seems sharper..... Is it just me???
How to downsize MPG files with least quality loss
By windranger in forum Newbie / General discussionsReplies: 11Last Post: 28th Mar 2012, 14:37 -
mp3 downsize
By devdev in forum AudioReplies: 7Last Post: 8th Aug 2011, 15:17 -
Best Program To Downsize AVI With Little Quality Loss?
By blazin-j in forum Newbie / General discussionsReplies: 5Last Post: 6th Nov 2008, 22:30 -
Need to downsize a few videos to burn on DVD
By UmmAddan in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2008, 18:54
