Hey Forum, I did some looking around because I wanted a good video converter that can pretty much convert all formats to any format i needed. I decided to give WinAVI Video Converter a try and I downloaded the shareware for a trial. Now, Here is the problem...The program is telling Me I need A Real Media Codec (9 or higher) and a Windows Media Codec (9 or higher). I looked all over the internet and I can't seem to find these codecs. Can anyone tell Me where I could find them and If they are free or not? I appreciate any and all help since I'm a Newbie. Thanks Everyone![]()
I don't know what you were searching for then ...
Google found these within 30 seconds ...
http://www.microsoft.com/windows/windowsmedia/format/codecdownload.aspx
http://www.free-codecs.com/download/MUSK_Codec_Pack.htm
http://kirkdis.micha99.net/funfilme/wm9codecs.exeIf in doubt, Google it. -
Load real media 10 & windos media 9/10 on your system and WinAVI will not ask you again.
Howdy-
Just a note...If you don't want to convert those formats just ignore the message; all the other formats will work ok without those particular codecs.
TomT
Starting over with WinAvi problems
By alex0000 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2010, 04:30 -
WinAVI 9.0 Audio synch problems
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 21st May 2008, 12:10 -
Codecs and problems associated with them.
By rock.freak667 in forum Newbie / General discussionsReplies: 3Last Post: 14th Mar 2008, 12:30 -
WinAVI Audio Problems
By thegun in forum Video ConversionReplies: 7Last Post: 23rd Aug 2007, 12:50
