i know that i've been told if compressing at 4444 doesn't work for me that i should try 4400... well that got me thinking - how small can you compress something?? like not to burn on a disk, but say for viewing on the computer itself - i wouldn't need the quality to be top notch, but decent nonetheless... thanks
-angie
Results 1 to 9 of 9
I think the more you compress it the worse of a picture you will get.
Mark VMark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
angie,
probably the lowest you would want to shoot for would be
a trade off of storage space versus file compability.
For instance if you are only wanting to store and fit several movie only rips to say >10GB, you could use QT Pro to
re-save the VOBS as QT movies using the 3ivx codec into smaller QT movies with great quality --and save space.
However, then you would have to re-author up to go
back to DVD."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
ive gone as low as 2222 so that i joined 2 movies for total of 4444 and it looked "ok"
really?? that's good to know... cuz that's pretty small - what's that, a little over 2G?? then i might even try smaller, just to see how it is... i was just wondering incase i wanted to keep a movie or two on my laptop (without taking up massive space). -thanks!!Originally Posted by galactica
-angie -
We did an experiment on this a while back with Terminator 3. Several of us found that no matter what you set the output size to, the lowest it would go was about 1.8gig.
(However you could shrink it further by running it through dvd2oneX one more time, using the 1.8gig as source) -
Or you could shrink it even further by throwing it in the Trash and emptying it, and then never bringing up that stinking excuse for product placement ever again...
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
i tried a bunch of different numbers and, in my opinion, 2200 was the lowest i could go and still get a good quality pic - 2.1G, which isn't too bad to keep a movie or two at a time on the laptop to occupy me from time to time...
-ang
Smallest FLV output
By curt3006 in forum Video Streaming DownloadingReplies: 5Last Post: 26th May 2011, 12:54 -
best quality smallest size
By Reckitt in forum Video ConversionReplies: 2Last Post: 27th Feb 2011, 09:39 -
smallest file possible in DVD quality
By spiked4life in forum DVD RippingReplies: 6Last Post: 24th Feb 2009, 09:57 -
AVI to MPEG smallest bitrate?
By michcio in forum Video ConversionReplies: 11Last Post: 29th Aug 2008, 20:09 -
Best (smallest) format for movie burning
By Choppa in forum Authoring (VCD/SVCD)Replies: 30Last Post: 1st Oct 2007, 10:38
