Whats Faster for a Cable Modem, USB or ethernet?
Ethernet. Even if your card is only 10Mbps, ethernet should be faster. Not to mention USB requires additional drivers and can cause additional conflicts. Plus the more USB devices you add, the more you're squeezing your connection.
Nothing can stop me now, 'cause I don't care anymore. -
ok, cool
I just bought a new mobo and it says 10/100/1000 mb for lan or somthing, is that good for high speed? -
You should have no problems...Originally Posted by gooberguy
But then again, we are talking computers correct???
makntraksIn the theater of the mind...
It's always good to know where the exits are... -
USB cable modem connections suck
They're a pain in the ass to get working correctly -
Ethernet all the way for your cable modem. It might be 10/100/1000 but all your likely to use is the 10. Even so its still better then a USB hookup.
Father-in-law had has DSL running off his USB2 port... I reconnected it via his 10/100 card and his performance increased 20+%.
ADVICE: Turning in dead cable modem
By Frank-0-Video in forum ComputerReplies: 6Last Post: 15th Mar 2010, 09:57 -
Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable box
By aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 12:21 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 08:06 -
Computer question, what makes them encode faster, unrar faster etc.?
By willhenderson in forum ComputerReplies: 5Last Post: 30th Sep 2008, 22:21 -
Silly question about cable modem and PC
By cim in forum ComputerReplies: 15Last Post: 7th Jul 2007, 18:15
