Not sure if this is conversion, but quite sure is a newbie question.
I want to use IsoBuster to extract the .dat but filter only m2f2 mpeg frames; however, when I backed up, I only copied the .dat files.
Is there anyway to convert those .dat file into the same kind that is extracted by IsoBuster?
thanks
What have you got, and what do you want to do with it?
I'll assume a VCD that you want to encode to some kind of AVI. If so, the way to get an mpg out of a VCD is to use VCDGear. Then follow one of the mpg to AVI guides found under "convert" left.
/Mats -
what I have is the .dat file from a VCD's MPEGV folder, and I was to convert it to mpg that is needed for TMPGEnc DVD Author.
I am not sure if it is the same thing you are talking about?? -
No, I was talking about ripping a VCD. But I think VCDGear is still the tool to use...
/Mats
Convert AVI to 3GP with Minimum frames-per-second
By JamesC2000 in forum Video ConversionReplies: 1Last Post: 7th Nov 2011, 14:23 -
convert DAT TO avi
By skorpinok in forum Video ConversionReplies: 1Last Post: 27th Nov 2010, 03:53 -
Algorithm convert DAT to AVI
By Nemo_wf in forum Video ConversionReplies: 5Last Post: 5th May 2010, 03:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
convert VCD.DAT/MPEG to RMVb with dual channel audio
By newbievideohelp in forum Video ConversionReplies: 15Last Post: 6th Nov 2008, 23:42
