Results 1 to 10 of 10
    Sep 2004
    hey all. i have some vids that were ripped from tv & they have icons on the bottom right corner (ex.hits tv) is there any way i can black out that corner on the entire video?
  2. You can use the de-Logo filter in Virtualdub.
    Sep 2004
    hey thanks a bunch.. the file im using is in mpg format.. but once i make changes in virtualdub, i must save in avi format, correct?
  4. I dont think Virtualdub encodes to mpg you may have to framserve or save as AVI then encode.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Frameserve it, don't encode to avi then to mpeg. Each step is a quality loss. Guide here.
  6. I just through that in , just in case he didnt know how. Thanks for the Link.
    Sep 2004
    thanks guys.. ill check out that link because i never frameserved before..one final question.. the audio that is on the music video is really bad.. i want to replace it with my own audio. Should i use virtualdub for this as well? I'm playing around with it now.. i added the wav file but it's way out of sync.. how can i add extra frames at the beginning to get the vid back in sync?
  8. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    You can change the timing of the audio under audio>interleaving>audio skew.
    Sep 2004
    hey zippy.. thanks!.. now i see this chops off the audio.& i lose about the first 2 or 3 beats from the song.. (but the sync is good). Now is there any way i can add frames to the beginning of the video instead of losing the first couple of beats?
  10. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Well, you could edit and save out a portion of the video as a seperate avi. Mark the in and out points then save selection, be sure to have audio and video set to direct stream copy. Open the saved portion then "append avi" to add the original. That would add to the beginning of the clip.
