Ive went through 3 standalone DVD recorders. Iv'e been trying to reauthor alot of the discs Ive made on these recorders on my PC and am having way too much trouble. When I try and play one of the .VOB files on my PC I am having problems. Eg. When i try and play a .VOB that is 45 mins long, WMP or any other program I use to play the file will say the file is only 10 mins long. I've tried using Chopper XP to edit my .VOB files, and for some reason , when I try and edit, the output file never matches up to the points of cut off. I've also changed the extensions of the files to .mpg and tried editing with TMPG and have the same exact problem. I'm starting to think that DVDs recorded on standalone recorders are not compatible with computers. The types of recorders Ive used are RCA, Philips, and Cyberhome. Please help!
Results 1 to 10 of 10
I also had some luck ripping with DVD Decrypter and then using TMPGenc to reauthor but for some reason it would only work reliable with RW disk not R that had been finalized.
Yes, the key is to demux and remux your VOBs. That's because DVD recorders tend to cut them in small cells (mine was using 30s cells, so WMP would only play 30s of it, and reauthoring in nero was a complete nightmare because nero was cutting the VOB into 30s chapters!).
So demux and remux, and you'll be in business. YOu can demux with DVDDecrypter, and you can remux in your authoring tool usually...
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
jeanl is correct. DVD Decrypter is a great program. You can use it to easily rip your DVDs to your hard drive. If you select IFO mode/no file splitting you'll end up with one lage VOB. You can also use it to demux the VOB files on the disc to seperate audio and video streams. Authoring software should be able to handle the seperate streams. If yours doesn't (for some reason), use TMPGEnc ro mux them to a standard MPEG 2 file (use the MPEG Tools option). Then it's cakewalk to reauthor them.
If you want to do any editing (transitions and such) Womble MPEG VIDEO WIZARD is one of the few MPEG editors that works well. It's a bit expensive, but it has a 30 day free trial.
Decrypter and Wizard are great programs. You simple can't go wrong!!!!!! -
You shouldn't need to rip it at all. Just drag the video_folder to the hard drive and let it copy. I use TDA to make the menus, since it accepts the vobs. I'm only really trimming start and end points, not any serious editing. These have all been done on +RW, and I never finalize (for RW you shouldn't need to).
OK i figured it out, nut Im sure Ill have some trouble remuxing ..I plan on using TMPG
Refer to the numerous guides for DVD Decryptor... Look in the guide section on this site.
DVD reauthoring problem: 1 movie on 2 DVDs
By WIGGER in forum DVD RippingReplies: 10Last Post: 23rd Jan 2012, 17:10 -
Ripping DVDS made in standalone player from VHS ..please help!!
By joelasso in forum DVD RippingReplies: 13Last Post: 25th Mar 2010, 03:25 -
DVDs made with ffmepgx
By dlg1989 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2009, 14:05 -
Reauthoring DVDs without re-encoding: Best Freeware / Open Source programs?
By video_brain_dead in forum Authoring (DVD)Replies: 1Last Post: 17th Nov 2008, 23:53 -
Best macrovision remover for standalone dvd - recorders
By K_cin_az in forum DVD & Blu-ray RecordersReplies: 41Last Post: 23rd Nov 2007, 15:22
