  1. I downloaded a sample video, MPG - NTSC format and burned a Video CD with Nero 5.5 but when I play the avseq01.dat with windows media player it shows the video with garbage, the same with my Panasonic RV30.
    So I tried with EZ CD Creator with no luck. Then I tried with VCDImager(BIN/CUE) no luck, and FantomCD(virtual CD unit) the .dat plays fine from the virtual Video CD, but when I make the CD Copy the resulting CD has the same problem (video+garbage), any idea? is it a problem with my CDRW (HP 9500)?
    Thanks in advance
  2. Anybody use HP cdrw? Which cdrw brand do you use and recomend for creating VCD?
