I just picked up an AIW 7500 from eBay to replace a TV Wonder VE. It looks like I have two choices for connecting the AIW to my sound card. I can connect the AIW output adapter to Line In on my sound card, but I also have an internal Aux-In connector on my sound card so I could also connect the internal connect the internal AIW connector to the Aux-In on the sound card. Is there any advantage to one method over the other?
I have the same card and use the internal connector to the AUX IN on my Soundblaster. I use the external LINE IN for other things though so didn't want to lose it. If you use the internal connector, bear in mind that the external flying lead to go into the LINE IN is still 'live' so could cause problems if it touches the back of the computer case. So this can't happen, I've wrapped a bit of insulating tape around the plug.
Internal usually sounds better.
I had issues on a few occasions with hissing , when using the external connection. Solved by using the internal connection.
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
ATI AIW 9800 Pro worst capture card ever?
By veedeo in forum Capturing and VCRReplies: 15Last Post: 1st Jan 2011, 19:41 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25 -
Problem with Connecting my Cable TV recevier with TV Card
By hadivelko in forum Capturing and VCRReplies: 2Last Post: 16th Feb 2008, 12:04
