  1. Banned
    Dec 2004
    SE4
    I put in the IDE drive to the pc i went to browse files and when i did a find search thing from start the logos had changed the mp3 logos were different but still opened up in wmp it's wierd and its happened b4, what is this issue??
  2. Member ViRaL1's Avatar
    Jan 2004
    Making the Rounds
    The icons change based on what the default application is to open them. A lot of media apps make themselves the default media player for every type of file that they support whenever you open them, like iTunes and RealPlayer. Some will ask, some won't. If you come across one that does ask, you can choose to not have it reclaim the file types it uses and tell it not to ask you again.
    (Hope that all makes sense)
    Nothing can stop me now, 'cause I don't care anymore.
  3. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    You can change them to anything you want and set the default program by going into My Computer>tools>file types
