I am attempting to convert a Divx file to DVD, so I am using Virtualdub to extract the audio as wave and then convert that to AC-3 using Besweet. But Virtualdub gives me an error message that says "No audio decompressor could be found to decompress the source audio format." When I check under File Information it states the following for the audio:
Sampling rate: 22050Hz
Channels: 2 (Stereo)
Sample precision: N/A
Compression: Unknown (tag 0055)
Layout: 284 chuncks (0.50s preload)
Length: 47704052 samples (1:06:15.33)
Min/avg/max/total frame size: 400/420/6000 (117K)
Data rate: 96 kbps (5.40% overhead)
I went on the web and downloaded an audio codec that listed for compression "unknonw (tag 55)", but I still get the error message in Virtualdub. I would appreciate any help that can be offered to get me past this problem.
I'm still interested in what people might have to say, but it appears that I may have solved the problem. I loaded the .avi file in Goldwave and save the audio as wave and am now in the process of converting it to AC-3 in Besweet. I wonder why Goldwave was able to do this but not Virtualdub, especially since the latter has never given me this problem before during multiple conversions.
I get that message a lot when trying to play AVI files with MPEG 1 Layer 3 audio (0055) with VirtualDubMpeg. All I have to do is press play a second time and it works fine after that.
How to convert DV to DivX or XviD using Virtualdub
By Baldrick in forum User guidesReplies: 52Last Post: 1st Dec 2011, 18:04 -
How to convert mp4 to flv in virtualdub?
By sgbd in forum Video ConversionReplies: 9Last Post: 2nd Oct 2011, 16:17 -
Help! Trying to use Virtualdub to convert 4:3 to 16:9
By jonny702 in forum Video ConversionReplies: 0Last Post: 13th Jul 2011, 14:53 -
VirtualDub "format convert" audio filter - how do I use it?
By Jedi787Plus in forum AudioReplies: 0Last Post: 12th Sep 2009, 16:35 -
Using VirtualDub or other program to mass convert?
By RedPenguin in forum Newbie / General discussionsReplies: 2Last Post: 17th Dec 2007, 18:18
