I'm trying to convert a rm tv episode to burn on a multivideo dvd. When i try to do so, it give me this error. What i;m a mising?
Encoding started on Sat Jan 15 00:41:33 EST 2005
MEncoder dev-CVS-041116-19:27-3.3 (C) 2000-2004 MPlayer Team
AltiVec found
CPU: PowerPC
Reading /Users/weizhou/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
success: format: 0 data: 0x0 - 0x9beb10a
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
REAL file format detected.
Not audio/video stream or unsupported!
I had the same problem with some .rm files. Try the following:
- Check the box "Open Terminal Window"
- After the process aborts with the error message you gave, hit the "Up Arrow" key to review the last command in the terminal window.
- edit it to remove the two apostrophes ( ' ) right at the beginning where mencoder is called, also you need to replace "Application Support" with "Application\ Support". Then delete everything between "-oac" and "-ovc", replace "-oac" with "-nosound", keep "-ovc" and everything else. Hit enter.
- the encoding should start, producing a movie with no sound. If that works, Use AudioHijack to capture the sound manually and convert it seperately.
I hope that this works for you as it did for me
How to get a quality DVD video from a downloaded 'flv format (Real Player)
By elaway in forum Newbie / General discussionsReplies: 4Last Post: 17th Jan 2010, 20:39 -
How to convert and burn a quality DVD from Real Player (.flv) download
By elaway in forum Video Streaming DownloadingReplies: 1Last Post: 17th Jan 2010, 18:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05 -
Convert Quicktime to Real Video 8 - OSX
By forsterr in forum MacReplies: 2Last Post: 15th May 2007, 12:40 -
Getting 0KB files when trying to convert Real Video to other formats
By j1201 in forum ffmpegX general discussionReplies: 1Last Post: 13th May 2007, 05:34
