I'm trying to make a backup using DVDShrink. I get an error saying that its too big for the disc and that I should use auto compression or disable some audio streams. I have it set to auto compression, but it's still telling me the output file size will be around 4,800 mb. I tried to set a manual compression ratio, but it won't let me compress it any more. The auto compression ratio is at 58%. Is there a limit on how much you can compress? I'm not concerned too much about the quality. I just want it to fit on one disc with all the original menus and extras. Any suggestions?
Results 1 to 11 of 11
De-select any unnecessary audio streams, shrink twice if neessary. Yes, your version has a limit on shrinking.
"Art is making something out of nothing and selling it." - Frank Zappa -
Remove one of the unneeded audio tracks. Or if you really need a 1:1 backup goto DL.
But you just cannt have everything in DVD5. -
Unfortunately all the audio streams are the same type and all are english. I can't tell which one I might want to de-select. Is there a version without a compression limit? or is that just stupid? I will try to shrink twice.... good idea!
You should be able to compress a littler lower than 58% w/ Shrink.
As far as the audio streams just start the main movie and right click in the preview pane and select the different audio selections. You may find a Director's commentary you dont want or there may be ac3-5.1 and ac3 2.0, one being DD5.1 and the other DD2.0. You can choose as both are not usually needed. -
Not sure why you can't get more than 58% with Shrink, I have seen as low as 50% before. While it's available, I don't like it. I go in and use a custom ratio to pull down the values of the menu and special features so the movie quality actually increases. You didn't list which version of Shrink you were using, but if it's older you may want to update.
I assume you have gone into Re-author, in which case why haven't you done "custom ratio" instead of "automatic compression" ? That should allow you to compress down to 40%
Just do DVD shrink again, or if you want to try it with one pass, maybe try DVD2One.
:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
Originally Posted by tonyiws
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 09:42 -
Need help with Audio stream format, VD/M won't compress
By talefing in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2010, 12:22 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
DVD won't read...won't create avi thumbnails
By ru5ty in forum DVD & Blu-ray WritersReplies: 6Last Post: 27th Jul 2007, 20:04
