just got thru converting my file via tmpgenc plus.
now i need to know what settings i am supposed to use in nero express to burn the dvd..
i have a 15 minute capture but for some reason it takes 40 minutes just to transcode the file for burning with nero express.
could someone please tell me how to speed up the transcoding process with nero express.
i know yesterday i burned an hour video with nero under one hour and ten minutes.
now its taking ages for a 10 minute capture!!
i think someone has changed the settings on nero but i dont know what the defaults are.
If your authoring program is transcoding, it means it wasn't DVD-compliant to start with, or you have the authoring app set to transcode all. in the preferences/options.
Look here for the definition of DVD-compliance:
nero 11 express
By tarzan54 in forum Authoring (Blu-ray)Replies: 12Last Post: 10th Feb 2012, 00:28 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 20:51 -
how to create folders in nero burning rom or express?
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Dec 2007, 00:54 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 08:35
