What gives here? I just loaded the firmware for the 3hr mode and the MV delete and decided to check my last recording and it looks like Ted Turner got a hold of it! Anyone else experiencing this problem? Does it have to do with the original or hacked portion of the upgrade (E20 version)? I tried a couple of commercial DVDs and they were not quite as bad, but they were still funky colored. I have not tried to record with it yet, as that seems futile at the moment. I knew this seemed too easy. Anybody?
Results 1 to 9 of 9
My flash went fine. Maybe you need to take it back to WalMart.....
You could flash back to the original firmware and see if the problem goes away.
Mine went fine also. Even fixed the fast clock problem.
Same way as you flashed the upgrade (with a minor exception). See the fine print on the following site for instructions
http://www.ss3f.com/ilo/r04.htm -
Just an update. I recorded a one hour show in the one hour mode and the quality of the recording was indistinguishable from the original (at least on my cheap equipment, although I guess the HP laptop really isn't...). The color issue seems to be with the recordings I had made before the firmware upgrade. I will be recording several programs in different modes this week, so I'll update if any problems appear.
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 15:48 -
Replacing a DVD+R Drive in an Ilo DVDR04, is it really that simple?
By V Bot in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Jul 2010, 10:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 04:12 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 15:58 -
Convert ILO DVDR04 into LiteOn 5005x!
By D'oh! in forum DVD & Blu-ray RecordersReplies: 16Last Post: 21st May 2007, 13:35
